1 - 11 of 11 Posts
Puttin in an 01 GT trans. I re-did the pin set up so it worked with my 95 V8 harness. Guy working on my car calls today and says the connector from my harness won't fit into the GT trans. Is this possible? Do I need to use the GT tranny harness?
The main plug is supposed to be the same, just a different pin-out. Maybe he was referring to the MLPS connector. You should use the MLPS from the '95.
1 - 11 of 11 Posts
