Hey Dan, I read somewhere that there is a kit for the '02 GT that comes with the MAF, cone filter, air box & possibly the wiring harness. If this is correct what is the part # and price. Thanks for any help.
FordPartsHQ
Hi There,
You can buy the complete 02 GT Air Box which includes the MAF and Air Filter for $169.95 plus UPS. This way you don't have to worry about a core charge. The pigtail will run you $29.93 for the 6-pin 6-wire, or $17.85 for the 6-pin 4-wire.
Talk to you later,
Dan Newman
FordPartsHQ
Chapter Director Coordinator
and in case you ask.. the 6 pin 6 wire will need to be spliced into current MAF and IAT sensor.. the 6pin 4 wire just splice into maf connections, and use your stock IAT
iat is intake air temp sensor.. the little thermo lookin gray thing w/ 2 wires
if you need help wiring the maf up.. check this link out:
http://www.blueovalchips.com/mafupgrade.php
jamesD said:
... the 6pin 4 wire just splice into maf connections, and use your stock IAT
You might as well get the 6 wire pigtail because your IAT will not fit anywhere after you replace the airbox and intake tube. The intake tube comes with a new IAT sensor in it. You might as well use it.
I was told that my stock IAT would just go right in but it is different. Trust me, I know first hand.
no, there is no place really for the stock IAT unless you cut a hole.. in which case, it needs to be Pre-maf.. not post maf. for a while i just had it stuck in the fenderwell where my filter was..
the integrated unit is better anyway.. brand new.. doesn't have 10yrs of mileage
Discussion Starter · #6 ·
Thanks for all the help!!!!
02 gt kit
Hey dan can you use the gt kit for a 94 thunderbird4.6, and if so is there any added horsepower? and will everything in th ekit be all i need to install or are extras needed, any help would be greatly appreciated
You wont get any extra hp with the gt mass air flow and air tube but the throttle response. You might get like a 1 hp or so :) from the added flow of the air tube but thats about it. Theres a write up on how to modify that air tube for the 94-95s. Plus your going to need a chip for the sensor
