A friend of mine just replaced the MAF on his 03 F150 5.4 with a Granatelli unit, and I was wondering if his stock MAF is worth putting on my bird. Sensor part # is XL3F-12B579-BA and the housing is PBT-GF40. Anyone know if this piece is a worthwhile upgrade?
Boom.
Everything after the first four is the same as my '02 GT MAF, which would lead me to believe that it is the same sensor. I am not sure, just making an observation. The 12B579-BA is the same. I believe that the first four identify the vehicle for use. My housing is also PBT-GF40. It is very possibly the same thing. I think the GT MAF was originally sourced from the E-Vans.
So I guess the question is whether the electronics and programming are the same for the two vehicles...anyone know?
Boom.
Tell you what, I'll find out for you tomorrow for sure. I work at a dealer and my dad is the Parts and Service Director at the same dealer, so I'll be able to find out definitively tomorrow, ok?
You are correct the first four numbers or letters identify the vehicle and the next five or so just tell you what the parts function is. Example I work with the struts the new part number for the front strut on the next mustang is 4R33-18045-** and on the Explorer it is 4L24-18045-**. They are both struts but are not automatically interchangeable. I’m not saying that this part will not work for you, I just wanted you to know that just cause that part numbers are close doesn’t mean they will work.
Boom.
Ok...sorry for the delay, but I haven't been able to find a definitive answer on this subject. I think that even if it isn't the same as the GT MAF, it may be a decent option to use. I would recommend that you contact one of the chip manufacturers who would be programming your computer to use a new MAF and see if they have the transfer range on your MAF. It could very well be a good option. Then e-mail or call Dan Newman to get the wiring harness that you need.
It's worth checking out at least, it is a new PI-spec MAF!
