1 - 11 of 11 Posts
Is an 03 MAF off a crown vic or an explorer the same as the mustang MAF?
Thanks alot
Will
and the part # for an 03 Vic Maf is 3W7A-12B579-AA are the sensors the same?
3W7A-12B579-AA or YC2F-12B579-AA or BA
YC2F-12B579-AA - 80mm
3W7A-12B579-AA - smaller but bigger than stock
but which sensor is better or more accurate?
A CV maf is smaller than the mustang.
The mustang maf won't work for you without a tune.
i have both mafs and my eec is tuned for an "02 gt" i also have a 85mm housing just wondering because if the vic sensor is more accuraute i want to put that in the 85mm housing and get a tune to match that
Can i do anything now with the 85mm that wouldnt require further tuning? or is the 85mm too much ?
i also have this 03 vic plenum 3w73-9a689-ca and was told it allows 15% more air flow is this true ?
anything after about 02 is better than stock. don't bother mix-n-matching. Your tuner won't want to deal with your car, especially if it doesn't need anything other than an upgraded oem-style setup (maf with matching housing).
Anything and everything dealing with maf swaps ABSOLUTELY REQUIRE tuning to have the car running properly.
1 - 11 of 11 Posts
