does anyone know what to do about the speed sensor from a 97 tbird to a newer 4r70w? the gear on the sensor is turned by the gear on the output shaft but the newer tranny, although it has a spot for a speed sensor, does not use one so therefore has no gears on the output shaft to turn the gear on the speed sensor. Any solution to this problem or just swap the output shafts?
