i need to pay it off firstLess thinking more acting dude..:tongue:
why punch the pan? You have a shurflow pump just pump t he oil to the valve cover or oil fill cap. Personally I would put a fitting in the valve cover so its not in the way of removing the oil fill but thats just me.
You are comparing apples to oranges. The rear mounted STS system affords over 10’ of oil cooling and natively have significantly lower operating temperatures then near mount systems and lets not forget that superchargers use oil exclusively for purposes of lubricity and not as a means of thermal regulation. There are plenty of reasons that no one would return to a valve cover (such things as lacquering, coking and conductive cylinder head heating just to name a few) It’s a free world but doing it the right way is always better.Theres nothing wrong with doing that. STS , many custom setups and even Sir Will has returned the pumped oil to the cap. Even the Vortech charger kits for the F series trucks return the oil to valve cover since the units are above the valve cover line.
If it were my car, I'd return the oil to the valve cover. I would also suggest using full synthetic because it will hold up much better to the heat from the turbos.
David
Why return the oil to the valve cover ? Because it's easier than putting a return into the oil pan or timing cover, and that is what a scavenging pump is designed to do. Another reason is it will give the oil more time to de-aerate before reaching the oil pan. The oil coming out of a turbo is usually frothy.Could you tell me why David?! Was planning in drilling a hole on tdriver side cover on front side..
Am planning on running full synthetic, need to change the old oil first, cars been sitting for 1.5 years but was thinking in getting the cheap oil and then changing to full sythetic. Or should I just run full synthetic when I change the oil?
I was reading over on the turboforums and noticed you decided to return the oil to the pan and encountered a few problems.
Just wondering if you got it running yet.
David
It's not too late...cut your losses and weld a patch over the hole in the pan, then run the drain line to one of the rocker covers. I'm a little confused by why you are grinding down fittings...are you welding this fitting onto the pan or trying to thread it into the hole you punched ?NO dude, sh!t. Should have listed to you and it would been easier to just drill the damn valve cover. Still having issues. I can not make the hole bigger on the pan (crank interfering.) So I've been grinding down 3/8 NPT fittings and the first one did not worked. Grinded it too much and when I put it on the pan, it was way too loose. So I bought another and will do it one more time. If this time does not work, I think I will have to change pan and might as well put a mark 8 oil pan and weld the bung, but we will see.. Stupid crank![]()
David
