1 - 18 of 18 Posts
I want to put the old bird on the bottle but she has 102000 mile will she live? :confused:
The motor will live. Not sure how long that 94 tranny will live though. Just make sure you are getting enough fuel and put it on a wideband to get your a/f before you start sprayin.
Well the trans just got rebuilt so thats not an issue. What shot would you run?
Start with a 75 shot as your fuel system will be able to support that, but still I would check the A/F ratio, if its off then i would look into getting a tune.
Whining Intakes Rock
I've heard that one before... hmm from me.
102,000 miles....that's nothing, spray away!!
I'm spraying and sitting at 168,000 right now :)
well what kit would you guys run if you were me?
second motion for the Zex dry kit.....75 shot on the stock fuel system to be safe.
Wet kits have issues with the 4.6l intake, and a direct port system is big $$
ok well what do i really need to run with a stock mustang gt. thats my goal is to run with those cars.
well what else do you have done to the car
Rebult or not, a 94 transmission is still a 94 transmission and the problems with them can't be fixed with a rebuild. Getting rid of the crappy one way clutch would be a big step, but there are other serious problems with those transmission. With the stock one way clutch... well... Be careful.
Discussion Starter #16
you have the mustang style intake right.
Discussion Starter #18
Well i guess that the 94 intake manifold is different than the 94 cars
1 - 18 of 18 Posts
