:xpp:
finish my 351w. looking for some heads with 1.94I valves.
replace the pumpkin cover.
remove rear K & replace mounts. (steel I hope)
move front K lower arm alignment U's
make upper shock mount. can't use the heim joint anymore.(rule)
need to make it more stock looking.
also swap to the afco shock
install the solid linkage gas pedal. (rule)
repair my home made front upper radiator support. re weld right side.
Remount aftermarket nose.
:thumbsup:
add cooling line to the rear of my intake.
:wavey:
I got one.
But remember there are at least 2 different covers.
:xpsmile:
I remember.. ;)
I have a second gen one..Which if I recall correctly is backwards compatible with the older diffs..
Good Luck!
