Hi:
I'm hoping one of you folks can help me here. I have a project that requires a pretty beefy 120V electric motor. As luck would have it, I have a friends spa motor we replaced a few years ago kicking around my garage. I took off the pump portion of it and have what I need motor wise now (has a threaded shaft at the end BUT I forgot how it's wired.
1) This motor has 2 terminals on it: H, C, and L.
2) I cut a PC power cord and came up with 3 wires: black, white, and green.
I'm a neophyte when it comes to AC wiring so please educate me. Which color goes to what terminal?
-gunn
PS. Nevermind. I called a spa place and they explained it to me
H = high speed = black wire for low speed
C = neutral = white wire
L = low speed = black wire for low speed
Ground = goes to terminal on body.
This probably explains why I tripped a breaker when I put black to H, white to C, and green/ground to L.
MODS: feel free to delete this thread if so desired
The terminal syntax is High, Low, Common Ground.
Those are usually pretty beefy motors, use 14 or 12 awg cords. :)
Sometimes on <1A fan-type motors it will be Hot, Capacitor, Neutral, Ground.
Well, I got it working. It's a testbed for a project i'm planning for my 0HP engine mod for my next lemons race.
Next step is to figure out how to attach a pulley/wheel to the end (as if it was say a tbird belt drive accessory).
-g
