Status
Not open for further replies.
1 - 20 of 121 Posts
n/a 373 posi out back..
what ALL does it take to run 13.2/13.5
stock block is this possible?
list all the things it takes to do this
I'm in the 13's with whats in my sig. Still have stock block for now.:eek:
Baddest N/A NPI in Canada
Well there is a couple of ways to achieve it and ensure you get there!
One method:
P&P NPI heads, Comp Cams, Bullitt/PI/SVO intake, Kooks Headers, Good exhaust, 3500 stall Torque Converter and a proper set of tires!
Alternate method:
Use P&P PI heads or SVO heads instead.
It is possible to get there N/A with less mods, but you WILL get there with the what I mentioned unless you can't drive!
Then start saving for another motor
lol, lets not get started on the npi to pi flow numbers, but pi will raise compression ratio and add a lil power that way, or you could have npi's milled alil bit to gain that cr that the pi's give. but yea heads, cams, headers, other minor boltons, stall, jmod, chip, and some sticky tires should get you there. im planing on doing all of these things, sooner or later, heads are about to be paid for and stock pi cams for now, then soon everything else:D
starve the hamster for a good week so that when you dangle the carrot in front of him it'll run way faster than before.:)
Like Titles Matter
Takes more than you've got you little punkass *****.
Whining Intakes Rock
Money... lots of money.
kdanner :gapteeth: dont let that be u, dont reply to my thread if ur gonna cry. everyone else. thanks for the input. ill keep these noted
If you don't want to go N/A
AED Blower (with other required bolt-ons), TC, J-Mod, gears alone would do it I would think.....
N/A.. The guys got it covered :)
Hey Kdanner, check your PM box please, I PM'ed you about your Bird and truck.
Fry Rice Specialist
ah haa....at first just go ahead and flame others and then now try to get help from others. i'll be ashame to still be here to ask help from people that i just flamed with. remember without the armed forced to serve and protect you will be worry if you still can own your car, the place you live in, the food you have, the safety of you and your love one, your freedom etc. than what mods can you do to run faster.
disclaimer: i don't care if this thread lock out or someone disagree with me but this is my sole opinion and i solely took full responsibility for it. thanks for listening.
Discussion Starter #15
ok this thread is about how to get a 4.6 into 13's n/a. u ppl need to learn something. if u have a problem with what i said in ANOTHER POST in a COMPLETLEY diff subject area then pm me. ill be glad to give u my words in there. so stop replying if it has nothin to do with this subject. geez ppl READ... older ppl mature pfft. then dont start it. i have a problem where i keep going until i get into trouble.
Fry Rice Specialist
JustinH said:
in before the lock.
I'm cracking up so bad here, lol.
:uppoint: :uppoint: :uppoint: :diablo: :king:
These are some questions about the 1/4 times, I myself was a little curious... Sounds a little cheaper than I assumed.
So lets not lock it yet :)
Fry Rice Specialist
have feeling that it will be lock.....soon enough......i'm feeling corky today.....:diablo:
1 - 20 of 121 Posts
Status
