1 - 20 of 116 Posts
i what a 145 mph speedo for my 95 cougar what do i need to get it outta? a sc sho? i'am going to get a set of white face gauges to from scott to help please thanks
what year?? any year sc?
do i have to get anything else besides the speedo??? will it bolt right up??
94-95 SC (Possibly earlier years, but not all had 145)
The speedometer is a direct plug and play swap.
thanks alot!!!!
My friend just did it. Shadow is right though, 94/95 is best. My friend bought a new 145MPH speedo from a dealer and just installed it. He also put white face gauges on it. It looks pretty good.
-Shawn
EDIT: BTW Toofast, I see you are in PA. We are doing a Albany NY meet august 2nd. I dont know how far it is from you but it should be a pretty good meet. My friend with the 145 MPH speedo will be there so you would be able to check it out first hand if you are planning on doing it after that date. The info for the meet is in the upcoming meet forum.
Also here are some pics for now:
thanks alot ill have to get my cay painted up! do you know how much your freind paid for the speedo?
I paid $70 shipped for an entire 95 SC cluster then just used the speedometer. :)
Once again you guys save my butt. I was just talking to a friend about this exact topic, and we weren't sure if the SC was a direct swap, and if white face was available.
Awesome... this place is great.
Now... what to do about the odometer....
wow thats steep..i will be hooking up a fellow member with one for 25$...dont worry john, im still on it........the "guy" is quite busy.
joseph
My friend, the ones in the pics, he paid $140 but thats because he got it new. Thats why there is only 32 miles on it in that pic. The other 70 just magicly went away. LOL
I carefully lifted the bar with the gears on it and turned the number where it needed to go. The very right side ones I left alone and spun the trip OD to roll it the rest of the way so as not to put stress on the plastic mounting point of that gear shaft.
Tere is a speedo shop in downtown Kansas City, MO. I used to go to.
The work with recalibrations for both Ford and GM. they also do custom reccalabrations for speedo replacements. I am sorry that I dont remember the name of the shop but they do excellent work.
anyone in the KC metro area please look up under speedo shop sna please post the number.
Thanks
is there any way to get 145 mph speedos for 97? ive really been wanting one and don't wish to change to the 94/95 cluster (even if i could, i wouldn't want to, don't like how it looks).
Ok, so if I were to put one in, do I need to change the speed sensor? Or does the speedo just 'know'? I would like to get just the speedo (145) for my '89 SC, so if anyone has one for sale that will drop right into my existing cluster, I would be interested. Thanks,
Matt
1 - 20 of 116 Posts
