I'm looking at finding some 10" wide wheels for my car currently have 8's on all 4 corners do they make them for our lug pattern? I'm running 265's in rear 245's up front and zero traction. I have some 295's I want to put on the rear but will not fit on those wheels..I would like to do this without swapping bolt pattern.I no longer have a garage I can do this in which is putting a hault on a lot of other things I want and need done..so any insight on this would be great thanks
Brad (Cudaz101) at The Custom Wheel Shop has them in the Tbird bolt pattern.
I run 18 x 9's on my car with 245 front and 275 rear; with 285 drag radials and I got plenty-o-traction. :D
Which tires are you running? Do you have a trac-lok (posi) rear end?
Ive hot track loc 410's 265 3518's in rear bfg g force...and smoking the hell out of them anything more than half throttle ...it will start breaking loose at half throttle .. 272.5 Hp 287.7 tq
Nice numbers. What all have you done to the car/engine?
Is it forced induction or N/A?
N.A. mark8 pistons notched ARP head studs PI heads comp 270's beehive springs 12:1 compression....mark8 oil pan
Trick Flow plenum 75mm throttlebody C&L 80 mm mass air CAI (Mac) Kooks headers 24# injectors adjustable fuel regulator screaming demon coils and wires
Magnaflow DI / DO center mounted muffler 2-1/2 stainless all the way out to chromed stainless 3" tips
3000 PI stall, built trans, 4:10's track-loc and a dyno tune
You have a sweet setup
Thank you.
... and so do you.
I ran them at 28 and at 25psi still having issues looking at some 295/45/18's off a lightning gonna check clearance tire hieght might actually help traction. And speedo being off a bit
