1 - 13 of 13 Posts
Will It Work???
Will it physcially fit on the vehicle? Yes.
Will it be anywhere close to the proper diameter and load capacity for the vehicle? No. That size is OEM for a Ford Focus ... that should give you an idea of the size and weight of car they are made to support.
cheers
Ed N.
Its just For The Track..
I Run 205/65/15s already at the track
and I Use 215/50/15 Everywhere else N' No Problems..
Its Slamed To the Ground, So It Isnt Too Bad..
For strip use, I use 165/80/15, but only 1/8th mile. Would be a little concerned on 1/4 mile track.
I Love You..
btw..
where did you pic up thoes rims??
I want sum steelies!!
The fronts are spare wheels with the 165s installed. The rears are spare centers, mounted into 8 inch rims by Stockton Wheels. I will install custom drag wheels this Winter.
They look like Blazer Rims Is why I Asked..
That's an interesting look, kinda makes the car look like an Impala ss (the good years) in the front...
1 - 13 of 13 Posts
