Ooh, Ooh! I might have found a 90 SC 5 speed manual locally. I'm waiting for a response.
Anything in particular I should watch out for?
Motor mounts, were head gaskets done, vacuum leaks, coolant leaks, any rod knock, check for any wobble on the harmonic balancer, does the tach work properly, synchros for 2nd and 3rd gears does the ARC work, wear on the driver's side bolster, do all the functions of the seats work (6-way adjustment plus bolsters and lumbar, and make sure bolsters and lumbar don't leak), front ball joints and strut rod bushings, check for rust behind the ground effects, if it has a sunroof, does that work properly and not leak, do the auto seat belts work.
I think he said it all.
Yup, I have a good list thanks to MadMikeyl I don't know the miles on it yet and haven't seen it yet.
