1 - 2 of 2 Posts
I have a 1990 tbird n/a and when I go around a bend it knocks real bad and squeeks when its cold on drivers side.
I have new shocks , springs, upper control arms and tie rods.
A shop told me that the bushings are gone.....and $250 cdn to fix
Is that the sway bar bushings???? If it is there cheap but are the easy to install??????????//
You should have put this in the suspension section. I had a similar problem. It rattled everytime I hit a bump. It was due to my front end links being bad. They were fairly easy to replace at about $42 a piece. Check those to see if the bushing are worn. If you do have to replace them, make sure you get a separator tool to make life much easier.
1 - 2 of 2 Posts
