1 - 2 of 2 Posts
I was wondering if anyone has tried to use a flywheel from a 2001-04 Mustang 3.8? I have searched this site for two days, and not found any info on this. I did find that Standard Flywheel lists for both applications, with all dimensions the same except the Mustang flywheel is 6 lbs lighter. The starter is the same for both, as is the clutch diameter, spline size and teeth count. From what I have found, both motors are supposed to be internally balanced. The only thing I can't verify is if the bolt pattern for the crank is the same (both are 6 bolt).
I am putting a new clutch in this weekend, and would prefer to put a new flywheel on it. I know of the aftermarket ones that are available, but this car has been sitting for the last 12 years, and I want to drive it before I start putting high dollar performance parts in it.
Discussion Starter #2
Let me ask this...
Does anyone have a flywheel for a 92 SC that I could get the bolt pattern measurements off of? Any help will be greatly appreciated.
1 - 2 of 2 Posts
