I did a search, and couldn't find an exact answer.
One, because I'm not sure when the AODE crossover years/models are.
I can put (possibly it is an upgrade?) a 93 5.0L trans into a 92 V6 car/engine?
I'm not sure of the bolt patterns or wiring. I think (from searches) that even if the wiring is not exact, it can be swapped out.
Thanks for input.
Thanks for input.
No mn-12 ever got an aode, 4r70w's started in 94 you have aod's. It'll be fine.
Alan
Discussion Starter · #4 ·
Aod
Ok, I knew the 5.0L (1993 and several years before) got AOD's. But now I know the deal with AODE (or lack of).
Thanks for the info about the swap.
