1 - 20 of 47 Posts
Folks,
I don't know how you guys feel about this but I was considering using this forum as a place to publically document all of the work I do to the T-Bird in bringing it back from a $100 car to a daily driver/Saturday Braket racer.
My plan was to have an initial post with baseline data and info and defect list with a LINK to pictures. (I figured inserting the pictures would be un-needed added bandwidth)
To that end I start with the data
1994 Ford Thunderbird LX
VIN#
Purchase Price $100
Mileage 129,150
Door Tag Data
GVW 4387
GVWF 2509
GVWR 2351
Man Date 7/94
Paint - WT (Performance White)
Body - LX2
Mldg - C
Int Trim - XR
R - H (WHat is 'R')
AX - 5 (3.27 Open)
TR = L33FF
Calibration Code - 4 18P R10
Original Condition
1. Accident damage in three areas
a. Right side behind door
b. Entire front
c. Driver's door/fender interference damage.
2. Major oil leak
3. Transmission Slip
4. Low Coolant Light
5. Low Washer Fluid Light
6. Dirty but not terribly so
7. Check Engine Light
Link to initial pictures.
Discussion Starter #2
Diagnosis on day one.
Oil leak is clearly in the oil filter area. I plan to get a new adapter and gasket.
Low washer and low coolant lights were valid and solved by topping off fluids
Check Engine Light was diagnosed with NO KOEO coodes, NO KOER codes and two Memory codes
P0174 - Bank #2 lean and
P0402 - Excessive EGR flow.
Body Parts in the correct color are being sought.
DScruggs said:
...Oil leak is clearly in the oil filter area. I plan to get a new adapter and gasket...
I highly recommend an oil filter relocation kit. The only way to get the factory oil filter out is to turn the open end down so that all the oil dumps out onto your face as you are struggling to wedge it out. Imagine being able to reach up under the fender well and just unscrew the filter without even needing to jack the car up. :)
Some days you get the bear
Some days it gets you
Today I got his a$$ but good.
I can scratch that Oil Adapter and gasket from my list because this "massive" oil leak that finally prompted the previous owner to sell was just a
(drum roll please)
Loose Oil filter!
Final progress tally for today
The fascia is off.
Both fenders are off.
I found the source of the broken vacuum line.
The charcoal canister was broken in the accident.
Codes cleared and have not come back yet.
Interior and exterior cleaned and vacuumed (found a quarter!) Now it is a $99.75 car
Changed oil and filter (K&N filter)
Used 2 cans of Gunk and then hosed the hell out of the K-frame, Oil Pan, and undercarriage.
I also was a bit distressed to find that the front bumper bar is WELDED on.
New discoveries
RF Spring in broken.
Shifter button pops out
Brakes are worn. (While I have it apart I will do front brakes.)
I need to research rotors and I read about dual piston calipers?
So my parts list needed so far is
Already Located
Left Fender - Found
Right Fender - Found
Fascia - Found
Headlight Mounting Panel - Found
Right Headlight - Found
Left Headlight - Found
Right Corner Light - Found
Left Corner Light - Found
Left Door - Found
Need to buy
Right fender to core support bracket.
Charcoal Canister
Vacuum Hose
Need to decide
Bumper Bar (May straighten it)
Energy Absorber (May omit it)
Brake Pads
Rotors
Calipers?
DScruggs said:
Folks,
Sounds good. Would you mind keeping a running tally on the price of parts?
Where can you get one?
EDIT: Nevermind, summit racing.....
Today's minor Progress
Did a little price research today and bought a few things
Total expenditures to this point
Description Qty Cost Source Part #
1994 Thunderbird 1 $100.00 Lawyer LX
Castrol 5W-30 5 $13.56 Advance GTX
K&N Oil Filter 1 $12.88 Advance HP2010
Brake Cleaner 2 $4.88 Advance A5000
Degreaser 2 $3.54 Advance AAP1
Fuel Line roll 2' $3.98 Advance 1/4"
Connector 1 $2.48 Advance 1/4"
Front Bumper Bar 1 $47.00 LKQ 2502945
Charcoal Canister 1 $52.60 Dealer E5TZ9D653A
Oil Sending Unit 1 $9.98 Dealer E9SZ9278A
MLP Sensor 1 $74.03 Dealer F5AZ7A247AA
Overall Total cost $324.93
I installed the Canister, Oil Pressure Sending Unit, and repaired the two breaks in the canister vacuum line system.
Have any of you been surpised to find that the front bumper bar is WELDED on the the frame rails? That is somewhat rare.
Discussion Starter #10 (Edited)
Picked up some parts over the weekend!
Thanks to Jerry and Michelle. Great folks if you ever get up to the west side of Cleveland (Lorain-Amherst) area.
I now have the
Front Fenders $45 (They are going to be a temporary fix)
Fascia - $65
Headlight Mounting Panel - $35
Headlights- $30
Corner Light - $25
Fog lights and switch - $50
Both fender to core support brackets - FREE (Thanks)
Thanks again guys it was a pleasure meeting you!
I now have the
Fascia - $65
Headlights- $30
Corner Light - $25
Both to core support brackets - FREE
Wow! Thanks for the kind words! :D I left positive feedback for you (look at the little number under your username). Our single regret is that we didn't have more time to hang out with you! It was an absolute pleasure, and I'd *highly* recommend doing business with you. Keep me posted..........I'd love to watch the progress of this car! Great to meet you!
Minor Update
I have ordered
a pair of slotted/drilled rotors $89 shipped
a Ford Service Manual CD $5 (Wonder about that one)
I also dorve up to NY with my Brother-in-Law (Thanks Brian!) and met Chris (Pnyklr) in Mt. Vernon. I got the two doors he had for $60. It was a pleasure to meet him and I very much appreciate his help. Getting in and out of NYC was a breeze.
Today I will take a set of current condition pics and then start work. I still need to get door hinges though.
Pictures, we need pictures!
94ONAIR said:
If you want to do the 97 headlight swap I can sell you everything you need for $220 shipped to your door.
Just out of curiosity does everything include the headlights, corners, 96~97 header panel & hood needed to do it right?
Discussion Starter #15 (Edited)
Oh SNAP! Saw that as a sales pitch (although a very polite one) right off.
I have pictures and will post tonight. I need to figure out how to get the door panel off then I will pull the wiring. I plan to get the headlight panel and headlights on today as well as the right fender.
Discussion Starter #17
Today did not go very well. I did get the door off but I do not have hinges yet. The new rotors arrived about 30 minutes ago and they are not even opened yet.
No work on the headlight panel or fender yet. Raked leaves instead. Beautiful day today.
Hehe, don't get mad, but that red interior makes my eyes bleed. :p Good luck with the project though! Cheers mate!
Discussion Starter #19
That your eyes bleed influences me not in the slightest.
Have a good day!
Discussion Starter #20
Upper hinge F4SZ-6322800-B $48.43
Lower hinge F7SZ-6322810-AA $61.74
Added to the expense list
1 - 20 of 47 Posts
