10-4, i need to replace a bent condenser on a wrecked bird i bought (still holding a charge) so just wanted to make sure there wouldn't be any compatability problems.
Have 02 mustang GT fuel pump want come on .It's new I tried before installing and it worked fine.Checked fuses they good voltage at inertia switch is 12 volts on both wires but still no sound from pump .Theft light blinks slow when I turn key on and speeds up when turning engine over .I can...
hi
newbie here ,i have a 96 bird with some problems I'm not real sure about
1
last night when i got off work I'll describe this best as i can) my bird wont start when i turn the key it will make a buzz, or hum then start,last night it dinnt do this what i got is click-click from the same...
does the tank need to be completely dropped, or can the front end of it hang down far enough to manuever the pump assembly out of the tank?
if it can hang, is it necessary to pull the hoses that are connected by the worm style clamps (fill tube and vapor crossover)? it looks like these are on...
I have some questions about the wiring harness and ECU from a 93 bird with a 5.0. I'm new to the forums and Tbirds in general so I'm learning a lot about them as I go. I searched the forums a bit before but didn't find what I was looking for.
I am using an ECU and harness from the same 93...
