Hello All. I have a 1996 Thunderbird. 4.6. 4 Wheel Disc Brakes. ABS. No Traction Control.
My brake lines are all in bad condition. I will be replacing them all with braided stainless lines. I found all of the connections that I need to connect them at the calipers. However, it seems as though there are a lot of different proportioning valve setups over the years and not a lot of information available. Below is a picture of mine. It looks like the lines from the master cylinder go in through the bottom, then the 4 lines come out through the top. My question is what kind of fitting is on the "out" side of the proportioning valve? Any suggestion on what to use to change to -3 AN fittings? Any help will be greatly appreciated.
