diagram
Hey, do you have the wiring diagram for a 97 bird for the upstream O2 sensors? Specifically one showing the routing from the PCM to the sensors and back to the PCM. Trying to hunt down a problem in the heater circuit.
Gordon
The main connector is the same on all 104 pin EEC V connectors but the cap on the wire end has holes plugged for the unused pins that need to be drilled out if doing a repin
ooo, i was just looking for the pinouts on that bulkhead connector! is that the same for the 95 as well? i was kind of hoping to compare and contrast before i swap over my 96 engine harness, just to make sure.
thought i had these pinouts in my chilton manual but i cant find em >.> just the ECMs for all years and engines.
C161? Different pinout. In fact the connector itself is the opposite, as it ends up Female - Female if you're trying to pair a 96/7 engine harness to a 94/5 EEC harness.
that's what i thought, i was looking and noticed all the wire colors were different and the connector itself didn't line up right. but i assumed that was because of the different placement from the two years.
guess ill be swapping the whole ecm system and rewiring the floorboard connectors afterall. kind of didn't want to have to drop the trans pan for the TCC so soon >.>
