21 - 36 of 36 Posts
Was this a rear disk brake car? I need front and rear Spindles for 93+ Disk brake car, so I can do the Cobra hub swap. Also need a gas tank form a 93+, but assuming this one is rusted pretty badly?
Discussion Starter #23 (Edited)
Yes, rear disk. I still have all the parts you need. But not shipping the gas tank. The gas tank is in good shape, the heat shield
Has some rust, but can be cleaned up good as new. I see you're from Iowa. I can meet you in Madison, WI. For the front spindles, rear knuckles, gas tank $150.
how much for these? do you know if the wiper cowl and motor are the same for the 1995?
Wiper motor with cowl
Wiper arms with wipers
Shifter assembly
Im not sure about the 95 and 96-97. You will need to find out. Everything you listed $100 plus shipping costs.
Discussion Starter #25
Would you happen to have available the rubber seal on the inside bottom of the driver's door? The one with all of the plastic push pins the runs on the underside of the door. Think you can get that off while preserving the pins?
Unfortunately, the ice storms and -31° temps haven't been kind to my bird this winter.
Sorry the bottom door weather stripping is no good
evap canister
What shape is the EVAP canister and EVAP purge solenoid? I'm also interested in the trans cross member support. Shipping to 60609
Jerry
Would you be willing to pull the fuse boxes, under dash and in the engine bay? Leaving about 6 inches of wire, shipped to 27526. Thanks.
Discussion Starter #28 (Edited)
Jerry
Jerry looks good, here is a picture.
40 bucks total shipped to your door.
Transmission brace is very rusty, i would not use it. Sorry
Yea i can do that. 40 bucks shipped to your door.
Any one got the arm rest door? What kind of shape is it in ? Thanks
Thunderbird SC Shop ( https://www.tbscshop.com/ ) has a few interior door panels. If you want only the arm rest, you can write or call them and ask.
I meant the lid for the center console. Sorry wasn’t more clear.
I know that this is an old post, but gotta try and find parts for my 97 TBird.
I need the Header Panel also called the Headlight Mounting panel and Gauge Cluster Bezel.
I had to replace my Header Panel a few years ago and found a new aftermarket on ebay. It was a good price and fit well.
21 - 36 of 36 Posts
