I have a 1998 Mercury Mountaineer that has a headlight problem actually there are no headlights.The fog lights work and all the other lights work but the headlights do not function.The other strange part is the dash hi beam indicater is on .:confused:
Let's start with the obvious. Have you checked the bulbs?
All the bulbs are checked.No power at the sockets with a test light.I also installed a new Multi-function switch and no difference.
Johnny Bling Bling
headlight switch?
I solved the headlight problem on my Mountaineer.The center pin on the headlight bulb socket for some reason had corroded bad on one and really bad on the other.I replace both sockets and this solved the problem.I just wanted to thank everyone for the help.
Regards
Jim
Regards
Jim
Same thing happened on my 95 Tbird once... replacing the sockets did the trick.
