1 - 15 of 15 Posts
I need to thank all those that came and helped me in getting the 1MTNCAT back together this year. It was awesome getting behind the wheel of it again although I'm a bit rusty.
For those that don't know the setup it is as follows:
Factory stock 96 shortblock
Factory stock PI heads swap
Bullitt Intake & TB
Small Stage 1 VT cams
Underdrive pulleys
90 MM MAF
30# Injectors with 1/2" feed fuel line, aeromotive fuel pump, and trunk mounted Fuel cell.
Trunk mounted battery
Shortie headers with 2 1/2 to 3 Inch Exhaust exiting mid body
PI converter
J-modded 4R70W
4.30 Gears
When running the spray-- a Zex Dry Nitrous kit - 125 shot!
I ran the car at the ABM Nationals at Cecil County this past weekend with the Tracktoysracing.com group and friends. Track Day temps were good, traction decent, 15 MPH headwind/crosswind most of the day but otherwise a beautiful fall day.
Needless to say with it back together there are still a few issues, particularly on the nitrous runs that need to be corrected before coming back out in the spring.
First pass NA the car ran a new best ever of 13.12 @ 104.7MPH. Then all but 1 of the remaining passes were in the 12's. The best NA ET of the day a 12.94 with best MPH of 105.25. Needless to say I was happy. That was also with the larger 27" Hoosier QTP drag tires not the previously used 26" drag tires. The car is making more power and running stronger than ever on motor.
60ft 1.84
330 5.32
1/8 8.251
MPH 83.29
1000 10.800
1/4 12.94
MPH 105.25
After a few more motor passes to insure all was good with it, then it came time to try it on the spray. I Had an issue with my bottle while trying to heat it and get bottle pressure. Didn't realize what actually had happened until I had staged, made the run and came back. The connection at the front under the hood to the box was very loose. The whole time the bottle was heating it was leaking bad under the hood. After the burnout a huge snowball fell out from under the car. Needless to say there was very little nitrous in the bottle. It got a small hit partially through the 1/8 but then that was it. It was totally out. Numbers on that pass were:
60 1.64
330 4.92
1/8 7.72
MPH 85.00
1000 10.16
1/4 12.21
MPH 110.01
2nd Nitrous pass I borrowed Jasons bottle which had some in it but wasn't full. Got to the line and made a pass with it but bottle pressure was very low. This was also the only full nitrous pass run I got in. The numbers looked like this.
60 1.62
330 4.80
1/8 7.53
MPH 89.59
1000 9.90
1/4 11.91
MPH 112.35
Last pass I had the bottle where it needed though low on nitrous but had to abort the run between the 60' and the 330' mark due to other reasons.
However on that run the car pulled a 1.59 60 ft and left awesome even on the little tires before the other problem.
All in all a good first outing day. I just have to get the bugs sorted out on the bottle.
Plus's....The car is leaving extremely hard with the new set up, hooking then, spinning the small tires enough on the spray that it can't hold it. I have plenty of fuel pressure now with the new lines, pump and fuel cell. ALL 3 nitrous passes also had the front tires in the air! The mild weight transfer that I had hoped for is working. Just need to get things in place to hold the traction.... ie.. Tires!
What a way to end the season for me with the car running again now.
JP "Driller" was there with the big Lincoln and ran very well. Also, I believe some others may have had some new times too. Brian Larkin ran his Turbo coupe and did very well as did John Speziale with his Supercoupe (A new best for him). Jason Miller's car also ran a new best I believe. Mike Siska's car also made some nearly 134 MPH pass's. Thats incredible. We all had a good time.
It was good to blow the dust off the car since its been sitting so long. Also good to get with all the guys and gals for one last track day before the end of the season.
Thanks Guys!
Nice to be back. Hopefully I can get some of the bugs out by spring. But its looking favorable at least.
Great job, and good to see it out of hibrination. Now you can get the little things corrected over the Winter, and come out swings come Spring time. :)
Nice 60's! Were you leaving off foot brake? If so, how much?
Yeah, leaving off the foot brake at idle then smacking it. 60's were ok on the 27" tires. I generally run 26" on the motor with 60's around 1.80. Its all I had so thats what I used.
Thanks fellows. I'm pretty happy with it right now. I suspect there is a little more in it on motor, and I know there is on the spray.
VA Chapter Director
After Steve borrowed my bottle I borrowed his tires. On a just about empty bottle and a steached out blower belt that was causing me to loose 2-3 pounds of boost I still managed a new personal best of 12.44 @ 109.
Come spring Steve and I have a no bottle heads up match as his best is 12.94 and my best is a 12.95 with no bottle.
After we see who wins that race we'll crack the FULL bottles open and see how fast these things will go!
Yeah Jason. We'll have to try that.
Moderator, Red Sox Nation Rabid Fan, TCCoAAC Found
Congrats Steve!!!! I just happened to be lurking today and saw this. What's up everybody. Still got my Cougar, but haven't done anything to her for about 5-6 years, just sits in storage.... Maybe one of these days I'll get it back out... got distracted by my other toys, house etc.... ya I'm a sellout. :)
Sup friends! Whats up Shady!?
Hey you. With the job move and the 02 my 94 just sat there, I got a good deal on MagerThom's 97 and took it, then the engine blew and it sat for a couple years while I got the money for forged internals, just getting back into the MN12 game myself.
Discussion Starter #15
Thanks Jordan!
Nice to see you back around some!!!
1 - 15 of 15 Posts
