Ok so I am wondering does everyone know what they are talking about.... I just read an article written by Jerry describing the '93 Bonneville Mark VIII. The car went 182.xxx something for the fastest run. And it was running a two piece drive shaft... I don't think I will ever get up to that speed, but why exactly could they do this, and we can't???
Sam
Where is this article about a Bonneville Mark VIII?
Is this a modified Mark VIII running at the Bonneville Salt Flats?
Modified may be the key word..........................
It was a "stock trim" according to Jerry. Nothing major done to it really. They swapped out the stock gears and put in 327 I believe... They also swapped tires of course, to I believe Corvette tires... They took off the mirrors and not much else was done to the Mark... I will try and post the link to the article later today.
Sam
02 Explorer Pioneer
You better reread that article they did a ton to it including removing the rear brakes to reduce rotational mass
Bonneville Article
The engine itself was truly a production Mark 8 engine that was just blueprinted. The transmission was stock but we did search for rotating parts that had no imbalance and no runout on the shafts. The axle was changed to a 2.47 axle. The air suspension, which normally lowers the car about 20 mm when you get above a speed, was set to lower the car another 25 mm so the car would drop almost 2” from it’s static ride height. Aside from this, the only other changes to the car itself were removed rear brakes (for less drag), removed side view mirrors, some fabricated “belly pans” for under the car and some kind of air deflector behind the grill, and the skinny Bonneville tires. (Of course the car had a roll cage and a two-piece driveshaft).
None of that sounds like a ton of stuff... But I apologize they modify more than my memory rememberd... However none of that addresses the question. Why can they use a 2 piece to go 182.694, and everyone says that we can't go much above 110... Would switching out the gears to 2.47 really allow them to not worry about it, or am I missing something?
Sam
02 Explorer Pioneer
I guess I should have been a little less vague as well. I didn't meen to imply a ton of custom stuff but at bonneville little details make the difference. I wonder if he means a stock 2 piece shaft or since it is mentioned with the rollcage if it was custom. I am imagining a pillow block mid way with two shorter shafts. Hopefully someone in the know will chime in
Timb very true. And I was wondering that myself, but he didn't mention anything when he was talking about what they did to the transmission... Hoping someone can enlighten me... I am still planning on getting the MMX shaft, just wondering whats up with this.
Sam
Still wouldn't getting up past 180 spin the shaft at over 5k? That is what I was thinking, but wasn't for sure if swapping those gears would keep it from shaking apart...
Sam
