on my 93 bird n/a, the mileage and trip odometer numbers dont rotate (which has been happening for almost a year now). the mileage reads approx. 72k when it really should be reading close to 80k. the trip odometer numbers read 000. how can i fix this so that the numbers rotate?
also, my driver side reflector light doesnt light up when i turn on my headlights. im talking about the light that is rectangular shaped and has the tbird emblem on it, located in between the corner brake light and reverse light. how can this be fixed? i have been told that there isnt a bulb in there to replace, so would i need to get a whole new reflector lamp? thanks.
I wouldn't worry about the first issue, just get a new speedometer from Ford.
On the second thing you're going to have to find a junkyard with a good one and pick it up, or give a few hundred to Ford.
-J
