I have a 96 cougar xr7 that I’m trying to install a transmission from 2000 crown Vic. Wiring harness don’t match. 2000 has a circuit board in pan. What can I do to make it work as I’m limited on funding and experience. But I need my car.
Sorry new here just trying to get some help or advicePlease only start one tread per problem.
This is a bad decision imhoIt is sorry just trying to eliminate time consuming research
So if I drop the circuit board and attach connectors for wiring harness and apply it would that be sufficient or do I need a felon?I swapped the circuit board out on my trans and returned it to the older style of wiring.
Had to drop the valve body to swap out the connector.
This website is a wealth of information on the 4r70w, if you do a search i'm sure you can find what you are looking for.
If not, reply to this thread and you will be helped in the right direction.
Repin?So if I drop the circuit board and attach connectors for wiring harness and apply it would that be sufficient or do I need a felon?
