Manufacturer's Part Number: | Product Line: | Basic Operating RPM Range: | Intake Duration | Exhaust Duration | Intake Lift | Exhaust Lift | Lobe Separation (degrees): | Grind Number: |
102700 | COMP Cams Xtreme Energy Modular 2-Valve Camshafts | 2,200-6,200 | 278 | 282 | 0.550 in. | 0.550 in. | 113 | XE278AH |
102300 | COMP Cams Xtreme Energy Modular 2-Valve Camshafts | 2,000-6,000 | 274 | 278 | 0.500 in. | 0.500 in. | 114 | XE274H |
102600 | COMP Cams Xtreme Energy Modular 2-Valve Camshafts | 1,800-5,800 | 270 | 274 | 0.550 in. | 0.550 in. | 113 | XE270AH |
102200 | COMP Cams Xtreme Energy Modular 2-Valve Camshafts | 1,600-5,600 | 268 | 274 | 0.500 in. | 0.500 in. | 114 | XE268H |
102100 | COMP Cams Xtreme Energy Modular 2-Valve Camshafts | 1,200-5,200 | 262 | 270 | 0.500 in. | 0.500 in. | 114 | XE262H |
102560 | COMP Cams Xtreme Energy Modular 2-Valve Camshafts | 1,600-5,600 | 262 | 266 | 0.550 in. | 0.550 in. | 116 | XE262BH-16 |
102500 | COMP Cams Xtreme Energy Modular 2-Valve Camshafts | 1,400-5,400 | 262 | 266 | 0.550 in. | 0.550 in. | 113 | XE262AH |
102535 | COMP Cams Tri-Power Xtreme Modular 2V Camshafts | 1,200-5,200 | 261 | 267 | 0.495 in. | 0.495 in. | 114 | TPX262HR-14 |
102530 | COMP Cams Tri-Power Xtreme Modular 2V Camshafts | 1,000-5,000 | 253 | 261 | 0.484 in. | 0.475 in. | 115 | TPX254HR-15 |
102525 | COMP Cams Tri-Power Xtreme Modular 2V Camshafts | 800-4,800 | 247 | 257 | 0.484 in. | 0.475 in. | 116 | TPX248HR-16 |
1991-1998 2V SOHC NPI Camshaft | 204 | 208 | 0.482 in. | 0.482 in. | ||||
1999-2005 2V SOHC PI Camshaft | 192 | 184 | 0.535 in. | 0.535 in. |
XE278AH | Street/Strip, needs 3.73+ gears, 2400+ stall. Intake, exhaust, computer and valve spring 26113 required. Rough idle. | Fits 2V SOHC engines only. For 1999 and later performance improvements heads. Can also be used in 1998 and earlier heads with retainer to guide clearance modifications and Comp Cams valve springs. |
XE274H | Fits SOHC engine. Hot street cam. Use with 3.55-3.73 gears 2000+ stall. Computer upgrade recommended. Rough idle. | Fits 2V SOHC engines only. |
XE270AH | Hot street cam, needs 3.55+ gears with 2000+ stall. Intake, exhaust, computer and 26113 springs recommended. Noticeable idle. | Fits 2V SOHC engines only. For 1999 and later performance improvements heads. Can also be used in 1998 and earlier heads with retainer to guide clearance modifications and Comp Cams valve springs. |
XE268H | Fits SOHC engines. Mild street performance. Use with 3.23-3.55 gears. Good torque and power. Will work with stock computer. Noticeable idle. | Fits 2V SOHC engines only. |
XE262H | Fits SOHC engines. Stock replacement cam with more RV power. Better torque and power. Will work with stock computer. | Fits 2V SOHC engines only. Requires bolt-on cam gears. |
XE262BH-16 | Good torque with powerful mid-range when using a blower. | Fits 2V SOHC engines only. Requires custom tuning. |
XE262AH | Fits SOHC engine. Provides better low and mid range torque with more power. Will work with stock computer. Best with custom tuning. | Fits 2V SOHC engines only. Valve springs recommended. Designed to work with OEM performance improvement cylinder heads. |
TPX262HR-14 | Optimized combination for power and torque with acceptable fuel economy for daily driver or highway cruiser. Programmer upgrade required. | Fits 2V SOHC engines only. Requires custom tuning. |
TPX254HR-15 | Fits SOHC engine. Exceptional torque with good horsepower and good fuel economy. Programmer upgrade required | Fits 2V SOHC engines only. Requires custom tuning. |
TPX248HR-16 | Fits SOHC engine. Provides excellent low and mid-range torque and horsepower. Programmer upgrade required. | Fits 2 V SOHC engines only, requires custom tuning. |
