1 - 20 of 22 Posts
would a 2002 4.6 LINCOLN Continental fit in a 94 bird has anyone ever done this before, i think it is a PI engine if im wrong please correct me thanks
Rigel
PI it is. Will it fit???? Sure, I dont see why not!!! Will it be easy??? Really dont know about that one. Buy one and then let us know..
lol thanks alot man but are they Dohc or Sohc. i have no problem trying it out but just want make sure that it'll bolt in with any fabricating.
InTech 4.6L(281.0cu.in.) V-8 DOHC SMPI 32 valve engine :ztoohot: Good luck!
I thought Continentals were DOHC unless they changed it somewhere along the line? I don't think the front drive 4.6's will work in a rear drive car either. So the answer is no, unless they changed something at some point along the way, which is a possibility I guess.
thanks alot i thought they change the continentals back to rear in 2000 maybe im wrong but ill check it out thanks
Rigel
I went and checked, they stayed FWD, they stayed DOHC, they did get the tumble port heads in 99 (tumble port is PI equivalent for DOHC). This gave them 275 HP. A Mark VIII is rated at 280 - 290. If you are getting the engine cheap enough it is worth parting out probably, especially having the new style heads. You couldn't put it in your car though.
I agree with 4 cam bird
thanks alot 4 cam bird and tx_cat
Rigel
FWD 4.6 block is different than RWD, I don't believe they are interchangeable ... weird mount attachments if I recall correctly. 2002 was the last year for the Continentals (thankfully). They were all 4.6 DOHC from 1995 to 2002.
cheers,
Ed N.
Continental 4V
The Continental 4V had a FWD block which has no motor mount pads on it and the RFOB is for an AXOD so it is the wrong bolt pattern for any RWD application. I guess anything is possible but you're talking about a lot of custom machining to make it work... Much easier to get a RWD 4V for an MN-12 installation.
Jedi Master
don't listen to TX_cat, he doesn't know what he is talking about...lol, you Can Not use that engine, do a search and you'll get your answer why its been discussed a few times.
JustinH said:
FWD block, won't work with the tbird, unless you want a fwd tbird with a nice Axod taurus transmission :)
Ewww. That has to be the second worst trans(axle) topped only by the A604 caravan unit. The 24v versions have AX4N's if it makes any difference,but no it's not any better than an AXODE (AXOD's went out with the 80's) I have lots of practice installing those transmissions in fact I have one of those cars being given to me next week. I put 5 used units in it and none of them lasted longer than 6 months 2 of them were bad from the start. Thats the beauty of installing junkyard tranny's I don't have to guarantee the parts they supplied :) He would have saved about $700 by properly rebuilding it the first time.
Alan
mn12xr7 said:
don't listen to TX_cat, he doesn't know what he is talking about, you Can Not use that engine, do a search and you'll get your answer why its been discussed a few times.
Dude, screw you man.... :rant:
mn12xr7 said:
i just clowning with ya bro....
Still screw you :rant:
P.S. hey bro, we hafta go to the drags before school starts...!!
if i recall this correctly the conti had the ax4n, but still junk. allen i know what you mean bout junk yard trannys! the one i had in the kitty lasted barley a year !(but i didnt have one to start with either)
Jedi Master
i should have my car before the week ends so yeah i'm down and so you can also creame your panties when you see my cat..
Yeah Yeah, bring it on!!!
1 - 20 of 22 Posts
