1 - 20 of 27 Posts
2017-06-09 New Personal Best
**Updated** New personal best is 14.2 @ 100 6/9/17, rounded. See link: http://forums.tccoa.com/26-racing/142440-2013-03-01-new-personal-best.html#post1955945
03/01/2013 @ 10:42:49 PM
'95 LX
Left:61
RT: 0.0475
60': 2.2549
330': 6.2770
1/8th: [email protected]
1000': 12.1390
1/4: [email protected]
Notes: 52* @ finish,~<3/4 tank,man. shift
I was hoping to do better, but I can take some positives from this. I beat my previous best by .36sec and 3.3mph. It did nearly as good as my 5.3L LS4 V-8 Grand Prix GXP when it had only a Cold Air Intake and a dyno tune. It would have beaten a few of the cars that had beaten me in the past like '05-'09 3V Mustangs, Z33 Nissan 350Zs, a Lightning, and a Supra.
Comparison to my GP-GXP best N/A pass
07/09/2010 @ 9:16:06 PM
07 GP GXP
Right:37
R/T: 0.0039
60': 2.0923
330': 5.9875
1000': 12.0338
Notes: Right off freeway,in Drive, ~3/8 tank,tc on,80*+humid
So I'm happy that I got an old Ford modular 2V SOHC N/A 4.6L to keep up w/ a newer "LS" powered car. It just needs a much better stall than the '04 Marauder converter provides. It doesn't have enough grunt down low.
What all mods have you done to it? Suspension? Miles? Just kind of trying to gauge where mine would run lol.
Well, I didn't have the results I had hoped for with ported nPI heads. The first set achieved the right flow numbers, but holes in the intake covered by epoxy were no bueno. So the same guy who ported those heads at this one shop, moved on to another shop and was tasked to port my next set. Needless to say, he was much more conservative and the car just didn't perform like I wanted. So not being able to get a hold of the rare "Renegade" heads, I settled for some Trick Flows. Also I had grown out of my Comp nPI "RV" cams and I had the shop order some custom grind Comp Cams...a good mix of the 102200 and the 102600 Xtreme Energy with a 113 LSA for good drivability. I got those two pieces in September 2011 and they finally got slapped on recently. Those mods + ET Streets are responsible for the difference between now and my previous bests. The tires actually slowed me down on my previous setup.
Have you got the slip you can post up on that pass and where it was run?
That 60 ft sucks if you have drag tires, and the eighth mile time and quarter ET and MPH don't seem logical.
Just saying.
What holes in the intake?
In the intake ports/runners? too much material taken out left a couple of holes. Hand ported.
Just saying.
Yeah sure whenever I get back to my desktop and find some free time I'll scan it up.
It is what it is. It hooked pretty good after mild burnouts at San Antonio Raceway. I have no idea why you would say real world results defy logic, but OK lol
LOL :tongue:
1MTNCAT is a stickler for numbers. He's the only member here who lists his 60' times in his signature.
It's a 14 second run... I'm not going to nit pick your times. Hell, I ran my best time of 14.7 on the old engine years ago on street tires. I know it can be done.
Congrats on your new personal best.
I'm not particularly nitpicking times.
I'm saying ET and MPH numbers don't coincide. Its looking close to 5 MPH faster at the eighth and at the 1/4 than it should be at that ET.
Acceleration rates should coincide somewhat with MPH. Those are 13.5 - 13.7 ET MPH numbers on a car that had a 2.30+ 60ft and high 14.4 ET. The MPH generally in those cases are around 73-74 MPH in the 1/8 and 94-96 in the 1/4.
So I'm saying how is the acceleration rate and the MPH so much higher and quicker but the ET not showing it.
Now, What is the rest of the set up on the car? Maybe that will clarify a few things. Somethings different.
Thats all I'm getting at.
Don't forget higher hp will get you higher mph not always higher ET times if he can't get into that power band right away. Mmaybe he's running 3.08 gears?
Full list of mods? I read maurader TC, ported npi heads, custom grid comp cams, is that all?
I don't think with a 14.5 you will be beating any 3v mustangs or lightnings. But either way congrats on the new times!
I hope not! If he's running a Marauder TC and drag tires there is no way the 60 ft should look like that to begin with.
Not to dwell on this but
Just for an example cause it was the quickest thing to get to for data:
13.600 @ 099.46 Joel Bender - 96 TBird LX 4.6L/N2O 10/2003
13.717 @ 104.42 91BLOWNBIRD - 91 TBird SC MPX 10/2012
13.850 @ 096.50 95badbird - 95 T-Bird LX gutted, stock 351W N/A 2008
14.063 @ 097.84 John Speziale - T-Bird 3.8L SC 8/2012
14.076 @ 100.14 Wolfer - 94 t-bird LX 4.6L 2V/PI N/A 11/2012
14.245 @ 097.69 XR7 Phillip - 90 Cougar XR7 07/2012
14.500 @ 093.97 Mgino96tbird46 - 96 T-bird LX 4.6L 2V NPI on E85 01/2013
14.512 @ 096.03 Chris_Murder - 97 T-Bird 4.6L 4V N/A 11/2012
14.717 @ 092.45 Trunk Monkey - 95 T-Bird 4.6L 2V N/A 12/2007
So also take into consideration there are a couple SC's and a 4V motor on that list.
I'm not disputing the ET. Nor am I disputing the run. It is good. BUT, Its not pulling that hard up top to run that MPH is all I'm getting at.
TM what MPH were you running at 14.7? He's running street drag tires not Street tires.
Boys, I been doing this for a LONG time.
Looks like you'll really get cornfused when you see what the '97 Mustang did in the other lane haha
Like I said, the car doesn't have enough grunt down low and needs a better convertor.
LOL :tongue:
Thanks, Trunk Monkey. It was my best 60' time too and this guy just wants to [email protected] all over that accomplishment.
3.73 FRPP. I've already killed 2 3Vs and a manual trans 350Z so that's moot. Haven't lined up with a stockish Lightning on the new setup yet however. I tend to tree people in my automatic cars.
With a MPH like that, you should definitely be doing better. Which converter are you using? That Mustang driver sucked big time. He should have stayed with you the whole time, his 60ft was atrocious.
Thanks for posting the slip and congrats on the new time. Like I said I wasn't disputing ET.
It should certainly be running much better than the 14.4 so you need to not worry so much about the MPH. Its making the power to be down in the mid- high 13's easily enough. More hook, Less slip, better ET and less MPH generally.
I see you have the TFS heads and aftermarket cams. That along with the wheel spin now things are starting to make a little more sense with the MPH. What is the engine combination & rest of the set up.
Glad I got mentioned I'm shooting for better numbers this year fooling around with tire pressure, street slicks, weight loss, shift points, reaction etc. I'm hoping for at least 14.2 this year. Any tips for better RT? I'm considering a hand brake to help flash the converter before the launch my left foot doesn't react well with all the additional hardware inside of it. I keep practicing but by the time I feel I'm getting dialed in the car is so hot under the hood that I know I'm not getting the most out of it.
Any tips for better RT?.
Leave sooner, like when you first see the 3rd yellow light.
If you add a hand brake, make sure it operates all four brakes. You could plumb a line lock to all 4 brakes, might need two of them. Just make sure you press the brake real hard when setting it.
That would react real nice, almost like a transbrake!
Al
Discussion Starter #19
Thanks for posting the timeslip.
I'll add it to the club Current best times and the All time best lists.
Thanks!
There's probably very little "nPI" any more. Maybe just the front cover, coils, water pump, computer, fuel pump, and A/C stuff. Finally had to upgrade from stock injectors.
Some other mods...
'02 Explorer block + PI intake + SCP headers and exhaust
Oh, and AccuFab 70mm TB, SCT MAF, '96-'98 Cobra intake tube + airbox
And once again, the tires hook. It just has nothing down low. It hurts the most off the line in 1st gear waiting for it to get into the rpm band ~3500+
Thanks!
Some other mods...
That makes more sense. An aluminum PI motor with TFS Heads, PI Intake and aftermarket Cams so there is nothing NPI about it. Its a PI motor.
You should certainly be in the 2.0 or less 60 ft range with that set up. When you do the ET's will come down significantly.
Get some practice time on the track and work on the start through the 1/8. The rest of the ET will come on its own.
You have a much better engine set up than I do.
1 - 20 of 27 Posts
