1 - 13 of 13 Posts
was curious if anyone had ran this size,
Looking to fill up the wheel well
i'm trying to decide between 225-70-15, 235-60-15 or 235-70-15
The 235/60 is shorter than a stock 215/70/15. The 235/70 is about 28 inches tall. If you want a little more height than stock go with the 225/70. I think the 235/70 would be excessively tall and would look a little funky, though it would definitely fit in the back. The 235/70 is only a little shorter than what you typically see on a stock s-10 blazer (235/75/15).
I just ordered a set of 255/60 15 for the rear of mine. They are almost identical in height with the 215/75 15's i have on the front. When those wear out, i will go to 215/70 15's on the front which will make the back a hair taller.
245/60 and 255/60 are both great 15" tire sizes. The 245/60's I have on the front of my Elite are just about identical in height to the 215/70's currently on my Thunderbird. Problem is wheel width. I wouldn't want those tires on anything less than a 7-inch wheel, and the stock T-bird wheels are only 6 inches. 255-width tires should definitely be on a wider wheel. Guess you'll just have to see how it turns out. It might work OK, you'll just have a lot of sidewall bulge.
Sorry to hijack...
But I was curious.
What's the largest tire that will fit on a 7.5W 18" rim? I'm looking to swap my back tires soon.
I want something tall enough to fill up the wheel well a bit more but not so much as to skid on the inside of the wheel well on a bumpy road.
Same with width, the widest tire that will fit on without looking like the tire is about to pop off the rim.
But I was curious.
A 245/45/18 is the widest recommended size for a 18x7.5 wheel and is roughly the same height as the various stock tires sizes available; slightly less than 27 inches. You can actually use wider tires without a problem, but you should get a wider wheel, such as 18x9. A 275/40/18 is about the same height as that 245/45, but a minimum of a 9-inch wheel is recommended. As sidewalls get smaller so does the tolerance of how wide a wheel you should use.
235/70 is a bit too big to be running everyday. I don't remember what the size was on the back of the car when I bought it, but I'm fairly sure it's about the same OD. I think the front was something like a 225/60 but don't quote me on that.
I went with the 235/60/15 cooper cobras and I really like the way it looks.
The tires on the front were in horrible shape, I got them for 477 and got it align'd for 79 .
I tell yah it's like driving a new car!!
Cool beans! That's what I have on mine. Cooper Cobra R/W letter tires, 235/60 on the rear, 215/60 up front for a slight rake look. Check out the gallery :D
Street Freekz
Given the choices you listed I'd go with 225/70/15. Beware, changing to a taller tire cut my gas a good bit for just 'city/town' driving but was still ok for 'open highway/trips'.
I ran 215/75/15 BFG's on mine without problem; 225/70 is almost the same height.
Jezz that bird looks like a 4x4 :eek:
1 - 13 of 13 Posts
