1 - 14 of 14 Posts
In looking for replacements for my junk Kelly Charger tires, I'm finding that the size, 245/60/15, is pretty rare. You can't find any performance tires of that size. All I find on some of the discount sites are Dunlop GT Qualifiers, Cooper Cobra's, Mastercraft Avengers and BFG T/A's of the 245/60/15 size...and of course a brand I'll never buy again...:rolleyes:
Well, that link only added one brand to the list I made above...Jetzon Revenger.
picky picky picky
lol
hehe
I suppose if I had the $$$, I could buy some 18" wheels and have a better selection of tires. :rolleyes:
well i just dropped my car off at sam's club to get this size put on and they told me they couldn't do it because they weren't the stock size. oh well i got four new BFG something or others in 215/70R15... do they not realize that there are people who intentionally put smaller tires on a vehicle to sell it faster ie used car dealerships that may or may not be stock size so they are contradicting themselves by not saying same size thats on there now or were gonna look at the sticker in your door jamb and see what size. im quite confused but i needed tires and i dont want to worry about checking the weather to see if ill have traction for the day or not.
/rant
Tyler
That stinks. You need to get buddy buddy with someone at a mom and pop shop. They'll try them on without being anal about it.
yeah i have plenty of people i worked at a toyota dealership a while back but they cant compete with the prices i got.
The 245 60 15 is indeed a rare size.
A popular tire in that size is the BF Goodrich Radial TA but they are a dated tire.
Had a 245 60 15 in the front and a 275 60 15 on the rear of my Dodge Ram.
When shopping I also learned the 245 is not too common.
Went with a Yokohama 255 front, 275 rear. Avid S/T.
Miles better than my old tires. Smooth, quiet, good dry grip and decent price.
I read your Tire review on the Kelly Chargers. Sounds like you might have ended up with Blems maybe???... Regardless if a tire is outta round they should simply be replaced/adjusted, unless it can be trued out and adjusted for the customer. Being a Long Time Kelly tire dealer we have had great luck with their products. I have never recieved a single complaint that I can recall. Its too bad you were not taken care of. But you never mentioned that you had made any attempt to get them adjusted either...??
Regardless to all of the above, Dunlop Qualifier & the Cooper Cobras are good choices as well, considering the size you are using.
Brad
Thanks for the info, Brad.
The story with these tires is a weird one.
I got a deal on them brand new (with install and balance) from a guy that used to post here that was local to me. They were to replace some 225's that I'd worn out. I didn't notice much problems with them at first, just an occasional rumble at certain highway speeds. Wasn't ever sure that it was the tires. This was three and a half years ago (I put less than 5K miles/year on the bird).
Sometime later, I was chasing a vibe and I had a Road Force balance done. This worked out for a while. Kind of took them back to brand new status. Also in this time frame, I had worked on the front suspension and had the car aligned a few times for different reasons. So alignment should not be an issue.
About the time of the new tires, another friend and I put in a trac-lock and we didn't get it quite right. I had a roar in the rear until I had a pro put in 3.73's with the trac-lock. So while I had a roar during the period of having the new Kelly's and also the bad setup in the rear, once I got the rearend fixed, the roar and other symptoms never really went away.
Recently, I had a local diff pro drive my car to rule out any problems with the rearend or bearings. He said that his opinion was that the tires were making the noise and maybe I needed to put new pads and rotors on the car. Front pads are fairly new but I didn't do new rotors. That's on my to-do list. When we got out of the car, he felt around my tires and said that all four have some defects that he could detect. There are uneven worn areas in odd spots. He personally knows and recommends the guy that aligned my car and said that these symptoms weren't indicative of a bad alignment job.
As far as getting work done on the tires...No, I didn't pursue that because I really wasn't aware of a tire problem until way after they would be financially serviceable. It always seemed to me that something else was going wrong with the car. And besides, I don't even know if the guy that sold me the tires is still working in the same place. I haven't had contact with him since he stopped coming here. He sold me them under the table IIRC.
I think you're right that I got a bad set. Kind of weird that all of them had some problems. How often to bad batches come out on tires? I dunno. I can't think of anything I did wrong except not drive the car every single day of the year.
I hope to rectify my tires situation soon with some 16's and some new tires. I just got a new job and my work will be a lot more consistent so that I can support the car better.
I just did a check for that size on tire rack. Where there used to be several now theres only one.
When I had the V6 97 Tbird I put Avid S/T's on it in that size. They looked great, and performed well. I think they're still on the car! (My sister has it now)
I ran two sets of the GT Qualifiers. Don't let their low price fool you. Granted, they're not the stickiest tires on the planet, but I had to push the car REALLY hard before they started to complain. And they would alert you audibly to impending slip so you would know when to back out of it. This is much better than tires that just start slipping with no perceivable notice.
With only 15K on a tire that is rated for 55K I don't see why they could not be adjusted. ANY Kelly tire dealer Can & SHOULD work with you to make it right regardless of where you bought them. Its not a warranty issue.
The odds of getting 4 bad builds would be slim Unless you bought tires that were kicked back for normal distribution. There should be an indication on the tire in some form to show this though. I am not really up to speed with Blem tires and ID'ing them because we have never brought any in our shop.
Lastly...I think you still have a decent case to get taken care of. Just take the time to look into it. Kelly makes a good product and is also great about taking care of build problems WHEN they arrise. BTW, Kelly does not make that specific size anymore & nor does Dunlop, so what is in stock out there is the end of production. They have the 255-60-15 being closest to what you have.
Brad
1 - 14 of 14 Posts
