1 - 11 of 11 Posts
I am looking for a set of drag radials and I found a really good deal on a set of 275/50/15 BFGs. I was wondering if these will (a) fit on a factory 15" wheel, which I am assuming isn't but like 6" wide or so, and (b) will the width clear all suspension and other components in the rear?
Kevin M
I just burnt through a set of BFG Drag Radials on mine really quick. The street will eat them up if you do a few burn outs. That is a really soft tire and the rubber comes off in chunks. I would save them for the track if you get them. I personally won't buy another set. I am thinking of some M/T Street ET and just running them at the track.
Good luck.
Scott
shaken, not stirred
275s will fit 15s? I thought the 245s i got barely fit on my 16s. Is there enough clearence in the wheel well for 275s? I think i remember that it was said that 275s wouldnt fit in the front due to clearence issues?
C.Hill
shaken, not stirred
Any modifications needed to run 275 in the rear?
C.Hill
shaken, not stirred
Well I would only use them for track use, so as long as it doenst rub too bad, I should be ok?
C.Hill
1 - 11 of 11 Posts
