1 - 13 of 13 Posts
Just for history, just cracking 100kmiles on my 90lx, we did the head gaskets last november.. so all the gaskets up that way should be pretty new..
About may or june, this thing started giving me an occasional rough idle with a check engine light.. it grew more consistent over a few weeks, so I pulled the codes..
it gave me a O2 sensor lean code for each side (was it 47 & 97?)..
So I bought new coi, dist cap, wires, plugs, and O2 sensors..
Well I changed it all, except the drivers side O2, which even with the loaner tool for the job, I just could not break loose..
cleared the codes, got the same.. lean on both sides.. well I guess it wasn't the sensor..
But, after than the car RUNS ok, seems to actually perform as it did before.. with the exception of little power from a stop (I'm gertting the idea that's normal) it seems to run fine.. once in a while I will start it and it'll idle like crap until it warms up, but even that's few and far between..
yet now the check engine light is always on.. and it bugs the piss out of me..
since then I've tightened up what seemed to be a slightly loose egr valve from the head gasket job, replaced all the vacuum lines (except the ones entering the firewall, which I plugged off for a test), map sensor, fuel filter.. and then ran out of ideas, except maybe a couple I don't want to face..
I've soaked quite a bit of dough into unrelated things on this car lately, I want it to be 100% so it's not all in vain..
What are my leftover possibilities here? please give me something I haven't thought of..:confused:
Confirmed V6 Nut
My 97 ocasionally runs rough at start up. I heard it is the nature of the 3.8.
well think of it this way. less things you will have to repair later down the road. you may want to try changing your cats. you run ****ty gas through your car? they could be clogged causing your o2's to go off. hell, if your gonna do that, might as well just do your whole exhaust system though. hey PCD how did you do your fold down rear seat? just curious i always loved those things.
I have little adversion to chopping out those cats.. it'd make it rumble nice ;)
but I have a hard time believing they would be clogged this long without showing any of the traditional symptoms performance-wise (running worse ->stalling as the car heats up, unusually small exhaust output, blowing seals).. I've had cats clog before, I'm seeing none of that.. if there is ever a miss in it, it's when it's cooled..
it seems to me I'm looking at something that went bad in a short period, has only a small impact, yet on both sides, and is as toast as it's getting..
I'm looking around for a fuel pressure guage atm, although I have a hard time with the idea of a weak fuel pump going a couple thousand miles without dying completely too..
you know, I soaked a good bit of cash into this problem.. and I think I just fixed it..
and I'm not happy about it...
ya know that schrader valve on the rail? well the cap for it was gone.. I just put a new cap on it..
every day for the last 6ish months the check engine light would come on within 5 secs of starting the car.. I just drove it a couple miles with that cap back on.. it never came on..
Wheres the kickin my own azz smiley at here?
wouldn't say all that, getting my 2nd strut rod bushing done tuesday after ~ 21/2 years since the last $400 job(had them both done)..
atleast it was only 1 this time, but ball joints to go with it..lol
I'll give it a week after I pay for that until the tranny goes.. :D
still talking myself into doing the heater core.. getting cold here..
soon I'll have a whole new car!
hahah i know! i've been through 3 trannys so far. the last one got cracked clean in half on the tail. i repeat got cracked clean in half. the U joint at the driveshaft came off at about 100 mph and whipped around and destroyed my trans. hopefully if i get this job im applying for i'll have the money to rebuild my car. my suspension is in some hardcore need of TLC. and the engine needs to be rebuilt
Confirmed V6 Nut
90lxbeater, Ugh, I did the heater core with my brother's help in his driveway. I spent the night because it took 8 hours the first day and 4 the next to change the heater core. All the time I had to listen to, "In my 85 Buick over there, all I have to do is open the hood and lift a panel to change the heater core....", the whole time.
meh.. now it's come back on for a while.. went back out just before I got home..
intermittent problems are worse than any :(
Resident redneck
where in ohio are you at? someone somewhere might be of assistance
zanesville..
seems to be staying out for the most part now, might even be an entirely different code for all I know.. but I'm going to have to give this one a rest for the next couple weeks, to concentrate on the other things for now.. if it's still an issue I'll get back into it..
1 - 13 of 13 Posts
