what can i do to improve the power...
read through this:
http://forums.tccoa.com/showthread.php?t=7727
is there any stroker kits for the 3.8??? better heads...
yes, you can get stroker kits through morana, SSM, or just get a 4.2 setup from a F-150
how much & where can i get a shift kit & tranny cooler???
Read through the trans articles here:
http://www.tccoa.com/articles/tranny/index.html
Also, if you want a built transmission, contact Darrin. He also sells pre-modded valve body kits. Trans cooler can be had from Jeg's or Summit
what gears should i put in rear...
Personally, I'd say 3.73's or 4.10's. I'd suggest getting an 8.8 and track-lok while you're at it. Several members on the board can build you one
it's a daily driver & every friday night starting in spring i want to race it when the strip opens...
If it is going to be raced and daily driven, go for 3.73's. You could also go for 3.55's. miller1995 runs these and I haven't heard any complaints
what rear do i have & is it posi or lsd???
posi is a chevy thing.
The correct term is Track-lock (unsure of the spelling). To find out what gears you have, read this:http://www.tccoa.com/articles/gears/gears.html
