1 - 12 of 12 Posts
Hey
Does anybody know how many cfm a supercoupe blower will flow. Thanks.
Will
Dim Bulb
interesting, the M90 only adds 44 hp at 10 psi and 12k rpm. I always thought it was more than that.
There is too much heat generated at that RPM to make much power.
yeah, I doubt those tests include the stock intercooler on the SC, although the stock intercooler may not be very efficient, it helps a lot with the heat monster M90.
-Thomas
Not all things Eaton revolve around the supercoupe Thomas. :)
Those tests are showing the M90's abilities without aid.
my point exactly ;) The intercooler obviously helps out because a supercoupe makes 70-80hp more than the NA v6.
So we agreed on this....
No help me with my TB problem. :)
Dim Bulb
How difficult is it to add the M90 to the 3.8 NA? I understand it's all pretty much just bolt ons, but do the NA and SC have the same heads/compression ratios?
the 3.8 has a 9:1 CR, the SC has 8.25:1, which allows for more boost. The SC also has a knock sensor which retards timing in the event that it starts detonating.
Man, you 3.8 guys get hit with that question every 5 minutes dont you. Its crazy how often people want information on that.
Someone should make a sticky about it. :)
1 - 12 of 12 Posts
