Driving home today my check engine light came on. Did the paperclip test and got three codes. 118- Engine coolant temperature sensor above maximum voltage / 0-40?C indicated. 157- Manifold Air Flow sensor fault, low voltage. 332- Insufficient EGR flow detected. Its really weird I get all these faults at once and I have a splitport swap so I have really no idea where to start.
I would look for a ground problem first since they all popped up at the same time.
Took a closer look and found a melted vacuum line running to the EGR. Cleared the codes and Ill recheck tomorrow if any of the codes come back.
Vacuum line could cause the EGR malfunction.
The other two codes .. usually a short would indicate Low voltage on the PCM side, the High voltage would be from an Open circuit.
Drove it around today and none of the codes came back. Ill check again later next week.
