32K Cobra B heads complete, timing cover, valve covers, $250 OBO All from a 1996 Cobra. They are low mileage, clean, and complete. I can do a valve job and new seals as well on them if desired for $150 more.
Would you consider selling the valve covers separately?
Thomas
Pics?
Thomas
This weekend, they are pretty clean from what I remember but not perfect. The Cobra build badge was removed also.
Heads
I may be interested in buying everything off of you related to the heads, I just have to reasearch how hard it would be to put this on a '95 long block.
Thanks for your time,
Brandon
Hardest part is the intake as Cobra intakes are a bit expensive. You could also use a Mark VIII intake for dirt cheap. What chassis is the motor going in? A MN12 needs Mark VIII exhaust manifolds and the Mustang needs Cobra manifolds (I think I have a set of Cobra manifolds)
BTW - It will bolt up right to that long block and I probably have the 4V chain guides as well if I searched. Your compression will be around 9.3:1
