I got a good deal on a 340Lph fuel pump. Will I run into any issues with the stock fpr?
Bryan
It might work. When I put my 405lph pump in with the stock fpr it had 45lbs of fuel pressure at idle. I had to use a super coupe performance fpr to fix the problem.
It may work but I bet the stock regulator can't keep up Also be leAry of some of the 340 as when fuel heats up there no better than a 255lph
