I used search and didnt come up with anything
I have a 351w with thats going into a 91 t-bird with a m5r2 and a Canton 15-670 oil pan
I dont think the mac long tubes will fit i was thinking about using shortys any thoughts?
Heads?
Hello
What heads do you have?
I run Fox pony manifolds on my Gt40p heads.
You will need to mod front K to fit the oil pan.(minor fix)
Try posting under Exhaust.
:wavey:
69 windsor heads wich are what the gt40head is based on
and that might be why I couldnt find anything on search I was looking just in the 5.0.5.8 threads
Heads
Hello
Those are good heads. take standard manifolds.
The valve train isn't the best(heavier than GT40's)
I have had my D0OE heads over 6000rpm.
I have GT40p's now. I do burn a couple plug wires.
(racing engine, high temps)
over the years, there has been several posts about headers on a 351w.
most might hit lower firewall, due to the taller engine.
:wiggle:
i wonder if there is a block hugger headder that might work
