A good set of aluminum heads will give you the most power...stroking the motor is worth power, but then you will be restricted by your cylinder heads if they don't flow well for the displacement.
A 392 stroker will make 500hp with good heads, cam and induction, It'll make power as good or better than those 383 chevy stokers that chevy guys are so proud of, and there's lots of those being build to make well over 400 hp.
