If you used the
GT maf, you need a tune for it. You're running lean, and it will cause problems if you don't fix it.
^^ This. You can't change anything about the MAF (or injectors, for that matter) without updating the computer with the new flow data. With a higher capacity MAF, not only would you be running lean, you would have too much spark advance. A double potency formula for spark knock.If you used the GT maf, you need a tune for it. You're running lean, and it will cause problems if you don't fix it.
That would do it. The sensor and housing must match. You can't put the factory MAF sensor onto the 80mm housing for the Mustang intake tube without altering its flow-rate characteristics.Im using the same sensor different housing.
Would the crank sensor be good maintenance to replace even if its not at fault. My engine bay has gotten dirty at times..That would do it. The sensor and housing must match. You can't put the factory MAF sensor onto the 80mm housing for the Mustang intake tube without altering its flow-rate characteristics.
The MAF sensor is the single most important sensor on these engines (well, along with the crank position sensor...). It's extremely precise and ANYTHING that changes the airflow characteristics around it requires a reprogramming of the PCM to account for those changes.
Fixes:
1) Put your factory MAF sensor and housing back on and use adapters to mate it to the GT air tube
2) Use the GT MAF and housing and get a tune
3) Keep your factory MAF in the GT housing and get a tune (will require a wideband O2 and dyno tuning because the MN12 sensor on a GT housing is not typical)
4) Put the factory MAF, housing and air tube back on
There isn't an option 5.
No pinging after going back to stock intake. Ill keep the gt intake around until i can get the car tuned.I wouldn't mess with the CKPS - they rarely fail completely (usually it's the harness that begins to short) but when that happens it's a no start/no run condition. The PCM needs the CKPS to know when the fire the spark plugs - so no (or intermittent) CKPS signal = no start/no run.
Coils are also one of the components on these that rarely go bad, but a complete tuneup is always a good idea especially if you're not sure when one was last done.
Let us know how swapping back to the stock MAF setup works out.
There's your problem right there. Ford parts all the way, especially coils. They're not cheap, but they last. Approx $150 at Village Ford.screaming demon coils
Have yet to install the demon coils still using the 190k old onesThere's your problem right there. Ford parts all the way, especially coils. They're not cheap, but they last. Approx $150 at Village Ford.
These cars don't make enough power stock to need a different intake tube.
Al
I replaced all vaccum lines, installed the demon coils. still misfires at hot idle.. but it does run better and starts on a dime after replacing vaccum tubes and coils.The PCM sets idle speed by varying the IAC duty cycle and fine tunes the RPM by varying spark advance. If the IAC is slow to respond, if vacuum leaks are present, the actual A:F isn't stoich (either by the FPR having issues or your O2s being off) then idle will be unstable. Vacuum leaks account for a much higher percentage of unmetered air at idle than under moving conditions so with no other mechanical deficiencies issues manifest under idle conditions.
