1 - 10 of 10 Posts
Given three alternatives ... which would YOU choose to swap in to the '96 Bird?
1. 2001 Crown Vic. 53,000 miles. 30 day warranty. Tested excellent compression. Clean oil, etc. $700. This engine in located in Colorado - about 3 hrs from us. Thinking we could go pick it up tomorrow!
2. 2002 Explorer from Greenleaf. UNKNOWN mileage, but listed as titled for fleet. I assume this would indicate good maintainence. $1375 shipped. 6 mo. parts only warranty.
3. 1996 T-bird engine from Greenleaf. 19,000 miles (so says Jay at Greenleaf.. can this truly be possible??) If milage is true, then would be easiest of all swaps! $1075 shipped. 6 mo parts only warranty.
Help me out here, guys! Jon needs a good (RUNNING!! LOL!) reliable car!
Marcee
I'd go with option one...primarily b/c he'd get more power and the $300 difference would be the money for an engine tune.chip :) Still gonna need some other stuff to do the swap, regardless what engine since the 96+ tbirds are different than the 94-95. Do a search under "PI engine swap" or just "Engine swap" and you will have most, if not all the answers you need.
I cant comment on the other two but I would definetly not choose the 96 Thunderbird engine. Doesnt make much sense to replace same pos engine into the car, definetly go newer. I would have thought Greenleaf would have had alot more choices that just the 1 expo.
I'll do some searching myslef later to see if I find anthything.
Dave
edit: kk - great mids think alike..... :rolleyes:
I did a carfax thing on the 2001 Crown Vic and also called the guy (with the engine) back to ask more quetions and get the vin #
Not sure if this matters or if there is any difference? but this is what carfax had in it
Year/Make/Model: 2001 FORD CROWN VIC POLICE INTCPTR
Body Style: SEDAN 4 DR
Engine: 4.6L V8 EFI SOHC
Fuel: GASOLINE
Driveline: REAR WHEEL DRIVE
Manufactured in: CANADA
Safety Equipment: ABS Optional, Dual front air bags/active (manual) belts
Standard Equipment: Power Windows, Power Steering, Air Conditioning, AM / FM, Power Brakes, Tilt Wheel, 6-digit Odometer
Milage is actually 57,242, it was wrecked (no damage to engine compartment), and it has been sitting on the shelf (drained) since 6/7/04
Thanks for the help!
Marcee
It might have more "idling" hours than the low mileage might represent, but I would say that Option 1 would be what I would do, Option 2 with the aluminum block would be nice, but since you have a 96 with all the pieces in place, but a bum engine, you can swap over what you need to the CV engine.
02 Explorer Pioneer
There are a few subtle differences in the Crown vic like the TB faces the drivers side but that can be changed. I went the 02 explorer route (I'm pretty sure I was the first) and found it to be pretty straight forward plus the engine weighs less being all aluminum. If you do a search on my name and explorer swap from a couple of years ago you should find plenty of info on the swap and what was involved along with a parts list and wiring instructions.
I too am in Colorado and check out Ford Parts LTD in Denver. They had a Mark DOHC for 700 in good shape. I am sure they have more but that was the engine I was hunting for...just found one that was a better deal than that one.;)
I'd go with option one for the reasons listed. The Explorer engine would be nice, but I don't think it'd be worth the extra money.
02 Explorer Pioneer
canadianblake said:
hey timb what if any , did you havew to do to the 94 computer...does an 02 hook up easy to the 94 ?
Nothing has to be done but you can get some gains with a tune
1 - 10 of 10 Posts
