well i know some people put in the PI motors from explorers and mounts, how about the new 3V 292 HP explorer motor does that go in the MN-12s as easy? im sure its still too new for many to have them in if they even fit but would this be a lot better then the other motors?
Your not going to get a 3v to work without alot of $$$.
The 2v motor runs quite well with the stock 95 4.6L eec.
If I'm not mistaken, the 3V has a drive-by-wire setup meaning that there's no throttle cable. You'd have to rig up some kind of sensor on the pedal or convert it to a mechanical throttle linkage, but as JustinH said, it's gonna be a lot of $$$. And that's just one of probably many things to deal with.
02 Explorer Pioneer
More than the drive by wire the 3 valve uses variable valve timing and the 95 EEC won't be able to control that. In theory it would require using the complete explorer harness and EEC
Boom.
Which would also mean a 5R55 or some sort of standalone controller...it's a vicious circle...
I think I read somewhere that there may be a way to lock the valves in a certain timing position for just this purpose, but then your ether going to loss power on the bottom end, or on the top end of the powerband.
My 04 2v explorer motor had a Fly by wire setup and all i did was swap over to the 96 style plenum.
A 3v swap whould be doable but like Justinh said it whouldn't be without alot of Benjamins.
