What is going on my people?! Needing to ask some stupid but important questions about replacing the intake manifold on the 96 4.6 Tbird
I have replaced the intake this summer with a stock plastic npi intake but it leaked like a sieve and i was discouraged after working on it all that day i havent touched it since.
couple questions:
1. what is the best way to clean up that gasket mating surface on the cylinder heads?
i used razor blades and brakleen last time and it just didnt seem like it was 100% clean like ive seen in many pics/vids of the swap.
2. What am i using to lube the fuel injector o-rings for new intake?
I was gonna use Vaseline
3. should i replace the water pump while im in there this time
no issues with current one but it is right there when i remove the intake and alt.
4. Should i be using Teflon tape on both the sensors on that aluminum crossover?
5. My haynes manual suggest torqueing the intake bolts again when the engine is warm. is that dangerous considering they're plastic?
so far ive been collecting some parts for the swap because it is winter here in the north east (35 mins north of Boston)
I was able to locate a NOS non-PI intake from a local junkyard part # KIT F8AZ-9424-AAA the kit came with the intake with aluminum crossover, intake gaskets, alternator bracket, thermostat o-ring, and a couple bolts all have ford part numbers on them. The kit was ordered Back in 05 for a 97 Lincoln Town Car and the junkyard had been sitting on it for over 10 years. the gaskets of course were junk from sitting but ive ordered more at Salem Ford in Salem, NH
new intake
new thermostat
new thermostat gasket
new intake gaskets
new thermostat sender/sensor
i apologize for such a long post
Thank you all for reading and as always your input is much appreciated
please help
god bless and fly low baby
couple questions:
new intake
new thermostat
new intake gaskets
please help
