I have a 94 XR7 w/ 4.6L. Does anyone have any tips on removing the power steering pump. I am trying to remove the Timing Chain Cover. The manual says the front lower bolt does not come all the way out. I cant seem to get a socket or end wrench to it to loosen it even. Any ideas?
There is a bracket the supports the P/S line that will need to come off.
I removed the small screw at the bottom of the pump that retains the bracket for the return line. I cannot get a wrench in to loosen the fitting, which is covering the pump mounting bolt. I have tried long, short and even stubby wrenches to no avail. Any ideas? I am sure there is a trick to this, I just havent figured it out yet.
