1 - 14 of 14 Posts
13's or Mildly Broken
So I'm thinking a Cobra Intake swap is out of the question since I've got a stock hood, but what about swapping over to a 97/98 intake? Would I need a cowl hood for that too? The car in question is a 94 LX.
Thanks
-Melon
gen 1 mark intakes flow better than gen 2 mark intakes. 96-98 cobra intakes flow better than both of them.
dont let the height of the intake stop you from making power...i wont :)
:zwthstpd:
Still gathering parts & doing homework for my swap. I've headed to scout a 97 Mark mill 100% complete on Saturday for dirt cheap. All accesories, wiring harness ect. & I don't even have to pull it :D
Maestro if you get some time shoot me a PM?
OK - I'll keep the Gen1 Intake then. And a Cobra intake if I come up with one for reasonable... and a cowl hood.
Thanks :D
-Melon
thats the reason I don't have one for my mark swap. everyone wants it's weight in gold for those 96-98 cobra intakes
:zwthstpd:
roger that...
The 97 mark has some long inlet runners; I bet it flows pretty well at >3500 rpm...
or with a blower, lol. :)
I heard the 97 cast is junk.
If you look at the runner setup on a Gen II intake it is blatantly clear it is a POS.
The IMRC's and heads have two individual ports, but the Gen II intake manifold has one runner per cylinder that splits before the IMRC.
The problem is that the runners on the intake don't line up correctly with the primary and secondary ports on the IMRC. For example on some cylinders the main path of the air is dumped right into the secondary port of the IMRC, which is closed much of the time. And on other cylinders it is the exact opposite.
Somewhere on the web there are photo's of the Gen II ports showing how mismatched they are. :(
SCT, weren't you planning on using a cobra intake on your swap or do I have you confused with someone else?
EDIT: Looks like you did use one.
http://www.forums.tccoa.com/showpost.php?p=1302842&postcount=12
Yes .. it is all done, just a little bit of fabrication and creative thinking to get it all working on the Mark engine. What started out as a great deal on the Cobra Intake manifold for $100 became about $400 worth of parts by the time it was all finished. :D
1 - 14 of 14 Posts
