I have conflicting info on which pins the 96 cobra eec uses for the IMRCs and the knock sensors.
From the best I can tell, the connections are as follows:
IMRC input..................pin 8
IMRC Driver.................pin 42
L Knock sensor(-).........pin 23
L Knock sensor(+).........pin 102
R Knock sensor(-).........pin 32
R Knock sensor(+).........pin 57
96 Cobra is what we need to be for a dohc. :)
Can anyone with a 96 cobra evtm confirm those pin numbers? (I've googled this, thus the confusion :) )
96 Cobra EVTM
IMRC <-> PCM
5 <-> 8
1 <-> 42
Knock Sensors
Right: PCM Pin 57 (Yellow/Red)
Left: PCM Pin 32 (Dark Green/Pink)
Knock Sensors splice into shared SIGRTN (Gray/Red) wire sourced from PCM pin 91, 91 is a common wire to other sensors.
96 Cobra EVTM
IMRC <-> PCM
5 <-> 8
1 <-> 42
Knock Sensors
Thanks!
