This is probably a newbie question but I am curious. Which heads flow better? The 4-valve cobra heads or the 5.4 Triton engine heads? If the Cobra head flow better will they fit on a 5.4? (I.E. a DOHC Lightning engine?)
The cobra heads flow better then the triton heads, but good luck at putting a 5.4 DOHC in. It probably can be done with some modification, but all I have to say is good luck if you go that route. Look on the corral.net for more information on the 5.4 DOHC projects.
Russell
Boom.
Not sure exactly what it is that you want to do, but 4.6 4v heads will bolt onto a 5.4 block. The intake manifold would be a problem for you, but the heads will bolt on.
I always forget about the space thing! So many people tell me I have a big car that I just assume I have plenty of room! Any idea how wide that Navigator engine is?
