yep'
you guy's think a 10x18 Rim with a +43mm offset and a 295/45/18 would clear the back?
Lowered with Eibachs and rolling fenders, should be done anyway.
Thanks for looking.
Discussion Starter #2
Change of plans, looking now at
Front : 255/40/18 on a 9" rim. O.D 25.98 inch, 36mm offset
Back : 295/35/18 on a 10" rim. O.D 26.18 inch, 45mm offset (may be 43mm)
I'm just worry a bit about the 35 in the back.
Sorry, didn't see this thread earlier. Others have put 295/35R18 on the rear of an MN-12, it will go. You will probably find that you need to space those 10" wheels out roughly 3 - 4 mm to clear the stabilizer bar, and the e-brake cable will have to be strongly tie-strapped to the bar to keep them away too.
Post some pics once it's all together!
cheers
Ed
cheers
Ed
Thanks Ed'
will post some pic's when all is done. For sure is going to be a while.
Decided to go with the "stock" setup, 9" +36mm gets a 45 and 10" +45 gets a 40.
